Quad Level Shifter for external guitar effect and synth ?
rafyc
Post by rafyc » Mon Apr 27, 2020 5:04 am
Hi,
I have stereo pedals effect, desktop synth that i would like to use with my eurorack.
Best will be Attenuator and Level up.
Is it the case with this ? http://www.doepfer.de/a1804.htm
Is there any Quad level shifter ?
Thanks for advices
Re: Quad Level Shifter for external guitar effect and synth ?
Post by Kent » Mon Apr 27, 2020 5:21 am
What is the device? Is it a synth or a stereo pedal? If it is a desktop synth, you probably don't need anything. Many pedals don't require anything either.
What is/are it/they?
rafyc
Post by rafyc » Mon Apr 27, 2020 5:43 am
Hi so it's
- Strymon BigSky and TimeLine.
- Lyra 8 which is very low
rafyc
Post by rafyc » Mon Apr 27, 2020 5:46 am
If i understand send / return on the same In/Output ? :despair:
tuj
Post by tuj » Mon Apr 27, 2020 5:57 am
yes, using an TRS insert cable. I can't get the link to work but just google "trs insert cable"
jwm
Post by jwm » Mon Apr 27, 2020 7:55 am
this seems a treat..
thesparkthatthought
Post by thesparkthatthought » Tue Apr 28, 2020 12:41 pm
I heartily second the Black Locust for your mono FX send/return needs, but it is not stereo, so you'd have to use all four channels to get your Timeline and BigSky working, and they would not be stereo linked.
Those Strymon pedals do accept line level signals* so you might be able to get away with sending directly into them... it's worth a try at least. If you're looking for a stereo send-return solution, the Strymon AA.1 (https://www.modulargrid.net/e/strymon-aa-1) will do that--and nothing else--in 4HP, and two of them are cheaper than one Black Locust.
For the Lyra-8, it looks like you might be better off with just a preamp type module? (e.g. https://www.modulargrid.net/e/circuit-abbey-gozinta) Unless you're also wanting to send audio into it, in which case you would also need an output module or a send-return type solution. (e.g. https://www.modulargrid.net/e/malekko-h ... ry-snd-rtn)
You mentioned that the Lyra-8 is "low"--how are you connecting it currently? TS cable? TRS? What module(s) have you tried to plug it into? Any VCAs with higher than unity gain?
*Line level is not the same as eurorack level.
