Module with good headphone amp
dip_registered
Post by dip_registered » Mon Feb 03, 2020 12:17 pm
First post! Yay.
Wondering if there’s a general consensus as to which output module has the best headphone amp? Looking between 2-6hp.
Cheers!
xcc
Re: Module with good headphone amp
Post by xcc » Mon Feb 03, 2020 6:16 pm
I don’t know about best, but I’ve had the Make Noise Rosie and the 4MS Listen IO and they’re both great for headphone use.
LunaticSound
Post by LunaticSound » Mon Feb 03, 2020 6:28 pm
If you want quality I guess the ACL interface might be a nice option.
Edit: sorry, missed the HP requirement.
vidret
Post by vidret » Mon Feb 03, 2020 8:20 pm
2 hp: ALM headphone amp
3 hp: Erica synths pico out
4 hp: music thing modular has some nice bonuses, there’s some other ones here with the feature set of the aforementioned ones
5 hp: bastl ciao
dros3raq
Post by dros3raq » Mon Feb 03, 2020 8:57 pm
Pittsburgh Modular Outs is old, cheap, well built, and reliable.
Naenyn
Post by Naenyn » Mon Feb 03, 2020 9:01 pm
Prior to switching to Expert Sleepers, I used Pulp Logic’s 1U output tile for headphones/speakers output. Worked great!
-n :ninja:
My racks on ModularGrid
Find me on MuffWiggler's Discord
Antlerface
Post by Antlerface » Mon Feb 03, 2020 9:24 pm
Id second the ALM HPO. Sounds great, 2hp. Only downside is it’s 1/8” not 1/4”.
doomlove.
My Eurorack
soggybag
Post by soggybag » Tue Feb 04, 2020 12:29 am
I have the 4MS mix four, its 10hp but is also a four channel mixer along with a headphone out. I have the 1U Intellijel headphone out which works but doesn’t have another output, you need a separate line out module.
smithjohn
Post by smithjohn » Tue Feb 04, 2020 2:16 am
I have been happy with the Ladik headphone amp. Don't have anything to compare it against but haven't noticed any quality issues.
It has enough juice to drive my Sony monitor cans.
Only 4hp and has mults for the inputs to send elsewhere.
dip_registered
Post by dip_registered » Tue Feb 04, 2020 11:54 pm
Thank you all!!
fredke
Post by fredke » Wed Feb 05, 2020 1:53 am
The Bastl Ciao! is 6hp and sounds good.
They managed to make even a basic panel like that look a bit confusing, because Bastl, but I love it anyway.
sierraoskar
Post by sierraoskar » Wed Feb 05, 2020 2:04 am
Knob Farm Oots is 6hp and also includes a saturator and tilt EQ, which are helpful. The headphone jack is 1/8” though, which may not be what you want.
tardwash
Post by tardwash » Wed Feb 05, 2020 11:23 am
4ms Listen I/O is great. 6hp. 2 input channels and two stereo output channels. It drives my DT770 Pro headphones just fine.
MikeLeeBirds
Post by MikeLeeBirds » Wed Feb 05, 2020 1:31 pm
I love the Befaco Out 3.
Stereo line out and separate headphone out with cue switch.
All on 1/4” jacks in 4hp.
Fabong
Post by Fabong » Wed Feb 05, 2020 2:02 pm
I use the ALM HPO, does exactly what it needs to do and only 2HP. Incredibly shallow too so you can fit it in pretty much any skiff if that's a consideration for you.
Avant Garde a clue
oilpanic
Post by oilpanic » Wed Feb 05, 2020 7:59 pm
The only one I have tried is the Pico out. It’s quiet and have zero problems diving my hd25s. If I had more space and money I would have gotten the happy nerding pan mix. But that’s a mixer more than a headphone amp.
