FX AID - multi audio effect module
autopoiesis
Re: FX AID - multi audio effect module
Post by autopoiesis » Sat Apr 04, 2020 5:01 pm
mosorensen wrote:
Sat Apr 04, 2020 4:06 pm
igorrr wrote:
Sat Apr 04, 2020 11:11 am
Ok, added "Delay AUX" to the effects list. It works as requested: Right channel is used for send and return to externally process the feedback pass.
I have always been a bit confused about these "send / return" loops. Wouldn't I achieve exactly the same thing, if I multed the output from the FX Aid (the "send"), then ran it through a filter or whatever and mixed the result (the "return") with the original input signal before sending it into FX Aid?
yes but you need to use a mixer for that patch. two, actually, if you want to control dry / wet, because it only works when you set the delay to full wet. this is a lot more space-economical
mosorensen
Post by mosorensen » Sat Apr 04, 2020 9:26 pm
That makes sense. Thanks for clarifying.
igorrr
Post by igorrr » Sun Apr 05, 2020 10:45 am
johannes wrote:
Sat Apr 04, 2020 12:45 pm
iam curious about more exotic effects like (spectral) formant shift or spectral harmonizer.
would that be possible?
FFT spectral effects are not possible, but will check what can be done with similar sonic results.
johannes
Post by johannes » Sun Apr 05, 2020 1:29 pm
ok thanks, good to know.
how far can one go by using the fv-1 programming? what about a modal filter?
brandonlogic
Post by brandonlogic » Sun Apr 05, 2020 5:21 pm
Ooooo interested you see what you come up with!!!
I know you mentioned it might be doable before but what about a Vocoder mode?
zerodivide
Post by zerodivide » Sun Apr 05, 2020 6:40 pm
is there some sort of best practice for gain staging the FX Aid? curious how much volume I should send it for ideal results. Def gets distorted if I don't watch my VCA before it
brandonlogic
Post by brandonlogic » Mon Apr 06, 2020 8:25 am
attenuate your signal if you start hearing distortion/clipping. it's that simple.
mdoudoroff
Post by mdoudoroff » Mon Apr 06, 2020 8:35 am
The Spin FV-1 chip was designed mainly for adding embedded effects to inexpensive mixing consoles and similar applications. the chip itself has little headroom by Eurorack standards (±3v I think)—but what matters is how Happy Nerving designed the analog circuits around the chipset. In my experience with FV-1 modules, you will need to attenuate often—plan on it. Some of the FV-1 based modules (e.g., Z-DSP, Black Hole 2) have on-board input attenuation, which is nice, but there’s no space for another pot on such a small module as this.
brandonlogic
Post by brandonlogic » Mon Apr 06, 2020 9:57 am
i find i dont need to attenuate all sources. some sources are worse that others, super long notes and drones tend to clip more than shorter transients. it also depends on the effect and your settings. either way, its quite simple to deal with by attenuating and not an issue.
mdoudoroff
Post by mdoudoroff » Mon Apr 06, 2020 11:14 am
I’m delighted to hear that, because a friend and I are each ordering FX AIDs at the next opportunity! I’m guessing Igorr maybe did a smarter design for the analog input stage than some of the earlier FV-1 module designers. (The Qu-bit and Erica FV-1 modules I’ve had in the past required attenuation most of the time.)
igorrr
Post by igorrr » Mon Apr 06, 2020 11:33 am
You need to insure that input to FX AID is not over -7...+7 V to be safe from input clipping.
FV-1 has limited program length, thus spectral or vocoding effects, which need to work with many frequency bands, can not be done to satisfactory results.
Funky40
Post by Funky40 » Mon Apr 06, 2020 12:07 pm
i use the happy nerding 3x stereo mixer (6hp) in front of the FXaid.
Thats really a nice team.
on the other side of the FXaid resides my WMD mscl (stereo) compressor (+ 1hp blank)
Very happy with that setup !
For sale:........it won´t sell, so i stopp bother you ;)
SavageMessiah
Post by SavageMessiah » Mon Apr 06, 2020 6:07 pm
Yeah, I had a bunch of clipping issues in my initial testing but in actual practice I've never had any problems. It's a really great module.
McRINdk
Post by McRINdk » Mon Apr 06, 2020 6:11 pm
Mine arrived today from Schneidersladen, thanks people. It’s brilliant, 1am and I’m still playing with it. At this stage I’ll probably pick 4-8 favourites and re order them to the first 8 slots. As checking the cheet sheet is tedious and remembering the knobs, part LED positions etc is beyond me.
mosorensen
Post by mosorensen » Mon Apr 06, 2020 6:29 pm
I keep PanMix Jr. in front of FX Aid as a three-channel aux-send stereo effect loop.
Bob Borries
Post by Bob Borries » Mon Apr 06, 2020 6:35 pm
Added new delay's to pdf manual (muted and Aux Delay)
Download: http://www.vo1t.com/Euro/Illustrated/Ha ... FX_Aid.pdf
zerodivide
Post by zerodivide » Mon Apr 06, 2020 11:20 pm
not to sound like a Debbie Downer here, and yes attenuation isnt much of a big deal. However, in my normal patches, I have my VCAs at about 3 o'clock, up and I'm not clipping. But if I send to FXAid the headroom is very little and I need to reduce the VCA to 9 o'clock. its a significant reduction in volume if I don't want clipping or distortion. Seems a bit odd to be honest that I need to attenuate that much. I do run stuff pretty hot though generally as my theory is recording as loud as possible before clipping gives the best results
zerodivide
Post by zerodivide » Mon Apr 06, 2020 11:23 pm
Bob: thanks so much for that. Is it possible to draw in the preset dots so we know whats what easily?
a100user
All the gear, no idea!
Post by a100user » Tue Apr 07, 2020 12:11 am
You’re a star Bob
I'm looking for nothing at this moment in time
nrg242
Post by nrg242 » Tue Apr 07, 2020 9:48 am
there are more algorithms than available slots on the module.
Pick a bunch and make your own firmware to test out. its super easy using the Fx Aid tool on the website, with a custom cheat sheet generated as well. then you can trim the firmware down again to a more manageable number of your favorites.
Bob Borries
Post by Bob Borries » Tue Apr 07, 2020 4:29 pm
Here you go
tdallas
Post by tdallas » Wed Apr 08, 2020 2:19 am
Here you go
Wow, thanks a lot :hail: Those documentations are top notch!
scottmfr
Post by scottmfr » Wed Apr 08, 2020 11:09 am
I'm not sure if this is possible, but I'd love to see a digital waveshaper added to the roster similar to Audio Damage's ADM18 Shapes module. I suppose it would have to be done in two effects to provide both the Lookup and Algo modes.
zerodivide
Post by zerodivide » Wed Apr 08, 2020 3:34 pm
Here you go
that helps so much thank you thank you!
zerodivide
Post by zerodivide » Wed Apr 08, 2020 3:37 pm
guys I had an idea for FXAID and was curious if it was possible ..
to me it seems it would possibly make more sense if the "left" button was a bank button, and the "right" button scrolled through the diff banks in 1 direction. Pressing the Left button would take you to the 9th patch, where the top row is on dot 2 for example.
Seems it would be a lot more efficient at getting to your patch even if it was one directional. Maybe a future alt firmware could do this?
