Instruo I-ō47 / Instruo vs. ARP?
combathook
Re: Instruo I-ō47 / Instruo vs. ARP?
Post by combathook » Sat Feb 22, 2020 9:40 am
Thank you!
Here's one more. This time it's just an oscillator into the 2nd input channel going through notch, bandpass, and highpass with modulation. The first half has a delay on it because it sounded so good, but the second half is the same thing dry.
https://soundcloud.com/account/io47monosynth/s-H0Om4
Re:
Post by MindMachine » Sat Feb 22, 2020 11:23 pm
boubi wrote:
Thu Nov 08, 2018 1:00 pm
I saw the Neonach at SB18 and it looks killer..have enough filters but can always use more complex versatile controllers.
Somewhat reminiscent of the ARP 1050 mix sequencer - with more features. Interested in that too!
Check this budget version out: https://www.electronicmusicworks.com/eu ... patch.html
boubi - your music is as good as electronic can get in my book. :guinness:
FS: Pedals and Euro modules, Delta Labs
viewtopic.php?f=74&t=233636&p=3287718&h ... e#p3287718
moremagic
Re:
Post by moremagic » Sun Feb 23, 2020 12:32 am
Dogma wrote:
Fri Oct 26, 2018 11:35 pm
A multimode filter based on the ARP 2500 1047 ... The resonance can push it into stable self-oscillation
that seems like a bit of a contradiction; dennis colins paper on the 1047 made it seem that the 1047s most important feature was extremely high Q without oscillating
studioutopia
Re: Re:
Post by studioutopia » Mon Feb 24, 2020 3:03 am
There is a switch that turns on/off self-oscillation. It's definitely that 1047 sound, but it has some bonus features.
See here:
https://www.instruomodular.com/wp-conte ... kstart.pdf
I will add - this is an amazing filter. I've had it for over a month now, and it's taken over as my go-to filter. Still love my QPAS, Korgasmatron II, and Ripples, but the I-o47 is just so expressive.
combathook
Post by combathook » Mon Feb 24, 2020 3:54 am
I have a QPAS too. For some applications the QPAS and the I-o47 overlap, but the QPAS is much more tame. The resonance on the QPAS is almost like a very narrow Q setting on an EQ which keeps it from ever getting aggressive, but the pings are fantastic and easy to control. One thing I like to do is put a dummy jack into one of the outputs to focus the pitch of the resonance.
Are any other I-o47 users having trouble with out of control feedback and overdrive? This could be down to the design of the original 1047 filter, but I've found that the Instruo is not necessarily a filter I can tweak carelessly, because with a little too much resonance, a hot input, and especially with external FM coming in, it will very easily spike 10 to 20db.
Alex_Des_Rois
Post by Alex_Des_Rois » Wed Apr 08, 2020 1:54 pm
For those who have it, as a oscillator, how much octaves can it handle before being out of tune when playing via a keyboard ?
dysonant
Post by dysonant » Sun May 03, 2020 9:59 am
... Are any other I-o47 users having trouble with out of control feedback and overdrive? This could be down to the design of the original 1047 filter, but I've found that the Instruo is not necessarily a filter I can tweak carelessly, because with a little too much resonance, a hot input, and especially with external FM coming in, it will very easily spike 10 to 20db.
Yes, I will need to play around with it more, but I can't ever turn the resonance past around 11 o'clock without it stabbing me in the ear.
Whatisvalis
Post by Whatisvalis » Sun May 03, 2020 2:14 pm
Definitely gets wild past 11.
What are some of the uses for the 2nd input? The resonance controls the amplitude, but the input also flips the phase of the signal?
