Piston Honda MKIII dual morphing wavetable oscillator
dooj88
Post by dooj88 » Tue Apr 30, 2019 3:00 pm
Pighood wrote:DISGUSTITATING!!!! :love:
this is necessary... this is necessary.. life feeds on life..
jwise
Post by jwise » Fri May 03, 2019 8:57 am
New firmware for the PH3 was released overnight:
http://www.industrialmusicelectronics.com/
Voggg
Post by Voggg » Fri May 03, 2019 10:01 am
Nice! I finally had my first successful Harvestman/IME update this week with a new pickit3. Still kind of a wonky process but not nearly as frustrating as my mk2 attempts were.
Cortega
Post by Cortega » Mon May 06, 2019 6:08 am
is a Calibration needed after Update ?
mt3
Post by mt3 » Mon May 20, 2019 10:21 pm
Cortega wrote:is a Calibration needed after Update ?
No, not required.
mt3
Post by mt3 » Mon May 20, 2019 10:25 pm
Firmware Update ver. 1.5
Bug fixes:
* Eliminated leading zeroes from frequency display.
* Y axis attenuator properly updates either oscillator selection.
New features:
* Extended frequency resolution. Fine tune is finer, attenuated modulation is more subtle.
* Unison selections now feature fifths (like Hertz Donut).
Download here:
https://ime-assets.s3.amazonaws.com/upl ... k3fw15.zip
NOTE
Firmware updates are in the Harvestman subforum:
viewtopic.php?t=216927
If you subscribe to the thread you will automagically be notified of firmware revisions ONLY.
:party:
spinalbeatz
Post by spinalbeatz » Tue May 21, 2019 11:48 am
Just picked up the PH and HD not too long ago. Any recommendations on a cheap pickit3?
Voggg
Post by Voggg » Tue May 21, 2019 3:43 pm
spinalbeatz wrote:Just picked up the PH and HD not too long ago. Any recommendations on a cheap pickit3?
I got this one and it works just fine.
david_r
Post by david_r » Thu May 23, 2019 11:24 am
I'm using this one just fine:
GhostlyMostly
Post by GhostlyMostly » Fri Jun 14, 2019 4:45 am
what size SD card are you using?
any specific sizes and brands working better with it than others?
i am loving mine but really want to create my own waveforms and get back to dubbing with this and the V2
thanks for help in advance
:rastanana: :zen: :zen: :zen: :rastanana:
Everything in life is replaceable, except people.
Joined Aug 13 2011 as Indigo333
Bigwerm
Post by Bigwerm » Fri Jun 14, 2019 9:50 pm
Does anyone out there have a Piston Honda MK3 with metal shaft pots secured to the faceplate as in the description on the first page of this thread? Mine does not and I was just wondering if any do.
synonymist
Post by synonymist » Fri Jun 14, 2019 10:12 pm
Bigwerm
Post by Bigwerm » Fri Jun 14, 2019 10:17 pm
All of the pots on my module are nylon shaft and none of them are secreed to the faceplate.
synonymist
Post by synonymist » Sat Jun 15, 2019 7:05 am
Bigwerm wrote:All of the pots on my module are nylon shaft and none of them are secreed to the faceplate.
So much for marketing copy, then. :|
Thanks for confirming. I will check my Mark III modules later, but I expect to find the same.
rosten
Post by rosten » Sat Jun 15, 2019 9:22 am
I've been using a 16GB micro-SD card. The PH3 just loads the wav files into its internal memory though, so I doubt that the SD card size makes a big difference.
L.C.O.
Post by L.C.O. » Sat Jun 15, 2019 1:13 pm
I have not updated mine to this very recent version, so am not sure if that issue had been addressed, BUT:
The preset saving mechanism is not really doing what I think it is supposed to be doing:
When I save, for example, preset 8 to be my startup/default preset, next power up the unit starts with preset 7 loaded.
When I set preset 7 to be the startup, then when I power up it loads preset 6...
etc.
I think something is messed up in the code.
Anyone else observed that in their modules?
mt3
Post by mt3 » Sat Jun 15, 2019 3:09 pm
L.C.O. wrote:I have not updated mine to this very recent version, so am not sure if that issue had been addressed, BUT:
etc.
I am on ver 1.5 and preset startup works fine.
Which firmware version are you on?
In ver 1.2 this was introduced:
"Startup preset mode changed.
Under the "Startup" item in the global options menu, you may now select "Preset off", "Preset x", or "Morph x" where x is the preset number of 1-8. When the system is restarted, the module will boot into the specified mode with the preset number selected.
Note that if your Preset Knob Mode is set to offset and the physical position of the preset attenuator knob is not zero (or if voltage is present on the Preset CV input), this will affect the selected preset number."
yeatsvisitslincoln
Post by yeatsvisitslincoln » Sat Jun 15, 2019 4:29 pm
I got a chance to measure the current draw on this since the power specs have never officially been released. That Joranalogue tester is super convenient, for the record...
Power:
+12: 145 mA
-12: 45 mA
+5: 0 mA
I also updated specs on ModularGrid.
L.C.O.
Post by L.C.O. » Sat Jun 15, 2019 6:08 pm
etc.
Thank you for your comment, and pointers re: attenuator knob.
On startup my unit says firmware 1.2
I read the manual for this module twice, but I did not remember the bit about the position of the attenuator affecting the preset selection. I will have to double-check if this is my issue.
Side note: IF that is the case, I would say that is a weird implementation. I suppose the position of the attenuator should matter if/when the CV is patched in. But if the CV is not patched in, that really should have no effect on the preset selection... especially since there already is a big selection knob that serves that purpose. Otherwise we have two physical knob controls for the same thing?... unless I am missing some obvious logic to this one?
mt3
Post by mt3 » Sat Jun 15, 2019 10:52 pm
etc.
Sorry about that. The most recent version of the manual is up to date for firmware ver. 1.1
This implementation is for when the preset knob is in Offset mode and the physical position of the knob has a visually clear semantic interpretation. It is not an encoder but an attenuator, so this implementation would make the most logical sense (Occam's Razor).
The manual not being kept up to date does not follow Occam's Razor unfortunately.
synonymist
Post by synonymist » Sat Jul 20, 2019 12:52 pm
autopoiesis
Post by autopoiesis » Sat Jul 20, 2019 4:03 pm
my favorite oscillator, just ahead of the dpo (though they are barely comparable in timbre and features) and shapeshifter. sold my shapeshifter (first and long favorite vco) after getting the mkIII and putting it through its paces. strongly recommend loading in a bank of primarily sinusoidal waveforms - bank A from the e350/352 is great - as the factory set doesn't include too many good sine table progressions, important for exploring its (very good) FM and wavefolding (process a sine or tri wave through a sinusoidal waveform in external input mode)
Sinamsis
Post by Sinamsis » Sat Jul 20, 2019 4:39 pm
autopoiesis wrote:my favorite oscillator, just ahead of the dpo (though they are barely comparable in timbre and features) and shapeshifter. sold my shapeshifter (first and long favorite vco) after getting the mkIII and putting it through its paces. strongly recommend loading in a bank of primarily sinusoidal waveforms - bank A from the e350/352 is great - as the factory set doesn't include too many good sine table progressions, important for exploring its (very good) FM and wavefolding (process a sine or tri wave through a sinusoidal waveform in external input mode)
That's a really good idea, Im going to have to try this.
synonymist
Post by synonymist » Sat Jul 20, 2019 7:15 pm
mt3
Post by mt3 » Sat Jul 20, 2019 9:09 pm
Try wavefolding drums by patching drums into Piston Honda mk III via the EXT IN (while in EXTERNAL mode).
The following involve adjusting wavefolding depth (the volume knob) as well as modulating X, Y, and Z axes to provide a taste of the variety one can obtain:
