Make Noise Modules - Supplemental Documentation
Reason101
Post by Reason101 » Wed Oct 14, 2015 12:14 pm
I am trying to put together some supplemental documentation for the Make Noise Modules. This isn't meant to replace their manuals. This is to provide simple "cheat sheets" that outline the modules.
I'm a technical writer by day, so this is somewhat second nature to me. I also prefer to see a concise description of the module along with the diagram of the module, all on a single page. So that's the thought here.
Tony has given me his "ok" to do it. And I'm happy to share it with you. As a side note, if you're a developer, and you want me to put something like this together for your modules, let's talk. Will work for modules. :tu:
Notes: 1. The PDFs are high quality print format so you can print it out yourself. 2. The font size is newspaper (7pt.) - This is a compromise so that I can fit the most information on a page.
Any other feedback is always welcome. Cheers!
Rob
dpo.pdf
(311.87 KiB) Downloaded 433 times
erbe-verb.pdf
(325.12 KiB) Downloaded 340 times
optomix-moddemix.pdf
(263.77 KiB) Downloaded 452 times
echophon.pdf
(267 KiB) Downloaded 309 times
phonogene.pdf
(284.4 KiB) Downloaded 355 times
wogglebug.pdf
(298.26 KiB) Downloaded 587 times
rene.pdf
(579.31 KiB) Downloaded 582 times
pressure-points.pdf
(347.51 KiB) Downloaded 469 times
maths.pdf
(294.44 KiB) Downloaded 1070 times
telharmonic.pdf
(244.78 KiB) Downloaded 485 times
resonaut
Post by resonaut » Wed Oct 14, 2015 12:21 pm
This is very useful, thanks!
astromooses
Post by astromooses » Wed Oct 14, 2015 12:33 pm
Great work man!
nrg242
Post by nrg242 » Wed Oct 14, 2015 1:30 pm
super useful. thanks for this!
shreeswifty
Post by shreeswifty » Wed Oct 14, 2015 1:37 pm
TY!
jenz
Voltage Controlled Corpse
Post by jenz » Wed Oct 14, 2015 2:22 pm
Thanx Reason101!!! Super useful!!!
:party: :hail:
isi909
Post by isi909 » Wed Oct 14, 2015 2:32 pm
:yay: :yay: thanks dude
empirix
Post by empirix » Wed Oct 14, 2015 2:42 pm
cheers for that :)
Zymos
Post by Zymos » Wed Oct 14, 2015 3:02 pm
Nice! Thanks for taking the time to do that.
cger
Post by cger » Wed Oct 14, 2015 3:03 pm
That's really awesome!! Thanks!!
Jumbuktu
Post by Jumbuktu » Wed Oct 14, 2015 3:56 pm
Lovely, just what I need for the Tele!
joem
Post by joem » Wed Oct 14, 2015 3:59 pm
Nice. I wish all modules (not just Make Noise) had a one-sheet reference that's as clearly written as these!
stike
Post by stike » Wed Oct 14, 2015 4:24 pm
Thanks for this :sb: :sb:
Will you be doing one for Function or could I use the MATHS one?(channels 1&4)
Also don't forget to indicate where hand moisturizer is needed when you get to Rene. :twisted:
Just another onionhead
sagetone
Post by sagetone » Wed Oct 14, 2015 4:27 pm
This is great, Rob, thanks!
wes2600
Post by wes2600 » Wed Oct 14, 2015 5:03 pm
This is a great idea.
I have drawn a couple process flow diagrams to help me understand modules better. It would be nice if you could get these from the manufacturers too.
DanJGW
Post by DanJGW » Wed Oct 14, 2015 5:24 pm
Good work thank you!
hawkfuzz
Post by hawkfuzz » Wed Oct 14, 2015 5:45 pm
I was surprised this didn't exisf. Thanks for doing it.
Good luck with the Rene.
Anechoic
Post by Anechoic » Wed Oct 14, 2015 5:50 pm
Thanks for this, very handy!
computo
Post by computo » Wed Oct 14, 2015 6:23 pm
Very cool cheat sheet, gonna refer my students to this!
Reason101
Post by Reason101 » Wed Oct 14, 2015 6:23 pm
stike wrote:Thanks for this :sb: :sb:
You could probably use Maths for most of Function. I don't think it's exactly the same though. If I get around to it, I will. This is one of those "if time permits" kind of thing. So I'll do what I can.
To everyone else, thanks so much for your kind words and support. It is very much appreciated.
Rob
L.C.O.
Post by L.C.O. » Wed Oct 14, 2015 7:43 pm
thank you for sharing!
CountZero
Post by CountZero » Wed Oct 14, 2015 9:37 pm
Very cool! Thank you taking the time to put this together 8-)
dimeshow
Post by dimeshow » Wed Oct 14, 2015 11:31 pm
This is super useful, much-appreciated. Thanks for your skills!
goldenliustra
Post by goldenliustra » Thu Oct 15, 2015 1:13 am
Reason101, thanks so much – beautiful cheatsheets!
I just have noticed a small mistake, Maths Channel 3 offset range is +/-5V, not +/-10V
tmcnvs
Post by tmcnvs » Thu Oct 15, 2015 1:13 am
Very nice! Thank you for doing this!
http://timecanvas.wordpress.com
http://tsukimono.bandcamp.com
http://soundcloud.com/timecanvas
