What do you do when you want to mix 10+ signals?
TechnosaurusRex
Post by TechnosaurusRex » Mon Sep 08, 2014 1:05 pm
Well, the subject line says it all. I am a bit confused about what to do when I have 10+ signals. Looking at mixers, I am thinking that I might have to chain them. Or are there any other mixers with ten or more inputs than for example the one from erica?
bodo
Post by bodo » Mon Sep 08, 2014 1:07 pm
I think Lowgain's Submix will be your best bet.
Junk Rhythm
Big Bottom Shaker
Post by Junk Rhythm » Mon Sep 08, 2014 1:23 pm
Mackie Mixer
Pros: It has EQs
Cons: It will not fit in a skiff.
TechnosaurusRex
Post by TechnosaurusRex » Mon Sep 08, 2014 1:28 pm
Thank you for two good ideas! Right now the submix looks like it'll be what I'll go for!
russthebarber
Post by russthebarber » Mon Sep 08, 2014 2:06 pm
Do you have to do this within your modular set-up? A conventional external mixer would be a handy purchase if not.
maudibe
Post by maudibe » Mon Sep 08, 2014 2:08 pm
Circuit Abbey Unify + Expanders. It has pan. Comes in 4 chan expanders to add to the original 4.
Very clean IMHO.
cephalopod
Post by cephalopod » Mon Sep 08, 2014 4:31 pm
+1 on the Unify. Super clean, and all the pots are sealed so no scratchy noises when adjusting anything.
You can add up to 3 input expanders, so you can go up to 16 channels.
I use one in my live case and love it.
Daisuk
Post by Daisuk » Mon Sep 08, 2014 4:40 pm
I have two Pittsburgh mixers that go out to an ADAT (and into Live). They're cheap, and very handy. Can work as 4 separate attenuators for an external mixer, or for 4->1 mixer. Can easily recommend it! :tu:
Diao
Post by Diao » Mon Sep 08, 2014 7:26 pm
Depends on what you are wanting to do with the signals. If these are finished sounds that you are looking to record, I would recommend getting a decent mixer outside of the modular world. You can find good deals on analogue outboard equipment these days, especially second-hand.
That said, if these are signals you are looking to mix together for further processing in your modular (10+ waveforms to mix before going into a filter, for example) then your best bet would be some of the aforementioned modules such as the Low-Gain SubMix. There are some higher end VC mixers that are offered by Cwejman and Intellijel, but if you are just looking for a static mix than a simple "set-and-forget" mixer like any that have been recommended previously in the thread will do more than fine. :tu:
WTB: Mogami Eurorack Patch Cables! Please! I will gladly pay you way more than you paid for them! Help a guy out!
Jahbo
Post by Jahbo » Tue Sep 09, 2014 4:32 am
wow that Submix looks great!
Else i guess if you would not need individual volumes a pair of Intellijel unity mixers would do...
I want it all!
lm13700
Post by lm13700 » Tue Sep 09, 2014 11:27 am
this is also an alternative to the submix 7
http://www.modulargrid.net/e/blue-lante ... -mix-em-up
