Post pics of your frac setup!
It's going to be a reset in, the extra jack is not wired to anything yet. I bought it already modded off Darenager ages ago.cerebrosis wrote:Looks lke 3/4 step switch, clock out and stage leds.
I wouldn't have dared do it myself, what with drilling holes in the PCB.
I can take some photos tonight - it's not properly mounted yet as I need to finish wiring up the reset in. And there are some notes on the schematic that I'll dig up too.e-tron wrote:Werock, I'm just about to add LEDs for stages on my switch.
Any tips?
- Common Wiggler
E-tron - that rig is beautiful! I love the buchla
I'm not being sarcastic. it's nice to see somebody that doesn't give a shit about homogeneity in the rack
the most important track you'll ever make is the next
https://soundcloud.com/doom_asylum
https://soundcloud.com/wade_blazer
Ok, here's a couple of photos and brief explanation (bearing in mind I didn't do the mods)
Underside of PCB:
4 tiny holes have been drilled in the PCB - 3 are for the stage out LEDS, which connect via a resistor to the IC pins and 1 for a common ground connection. The white wire from pin 8 is the ground connection.
Top Side:
Ignore the gray, pink & orange wires, they are for the 3/4 stage select switch which has been brought out to the front panel.
The white ground wire from the first pic doesn't have any insulation on this side, so you can just see the bare wire marked 'GND' next to the 3rd jack down. This connects one leg of all the LEDs to ground.
The 3 stage out wires that we saw on the underside connecting to the IC pins are the legs of the 3 vertically mounted resistors, with wires going from the other eend of the resistors to the LEDS.
Electrically it is all quite simple, just connect the resistors directly to pins 3, 2 & 4 of the 4017 chip and the other end to the LEDs. It just involves drilling through the PCB, which could of course end in
And you have to drill holes in the panel for the LEDs.
I'll do my best to answer any more questions...
Underside of PCB:
Top Side:
- Cat-A-Tonic
- Lobsters love Muff
- Common Wiggler
here's my tiny little frac-baby:
it will sit above the anyware inseqt sequencer, and below the 8x8 vc-matrix mixer, in my center rack, once i have relocated my video synthesis modules to a portable 12u case...
a new
syn01-weevil is currently on its way over from the uk!
... and i'm planning to add some blacet, metalbox and synthesis technology f-series modules early next year!
cheers,
7n7
a new
cheers,
7n7
"the ordinary will ignore whatever they cannot explain as if nothing ever happened. and everything remains the same again..."
- Cat-A-Tonic
I know - thanks for posting those pics. Seeing your set-up made meCat-A-Tonic wrote:I did the same thing + a 1FU Mixer Processor.e-tron wrote: I'll be taking 1Fu off the WC and MW.
There are pics of the new panels somewhere around here.
go for it. My Mixer Processor is done. If space is a concern, it's worth
the effort.
Nice to see some new Frac system taking shape
The frac is inavading the euro...
FxCam_1324657365321 by sonofprent, on Flickr
...and the frac drum that lives next to it...
FxCam_1324657387166 by sonofprent, on Flickr
- solitaryzen
- Veteran Wiggler
- otoskope
- Super Deluxe Wiggler
Here's my growing bananafrac system. Mostly Bugbrand, but quite some wiard, blacet and metalbox, too. And a few odd ones. Just acquired a bunch of these modules used (from ekofisk), so not all power is sorted out, and where to put the vertical rack on the left...
But it's becoming a great system. The bugs are just fantastic, and in good friends' company they flower even more beautifully.
I also have a half-built PAiA 9700 rack, and one empty frame, a Doepfer basic system (to be sold) and a Wretch machine...not all sorted in the same shelf, yet.
/Palle
/Palle
+1numan7 wrote:awesome frac system, 'oskope!
cheers,
7n7
love the 'nana mankato
WTB: Miniwave Vowels & GR-New ROMs
http://analognoisemonster.bandcamp.com/
http://www.youtube.com/user/rezzn8r
- otoskope
Yes, isn't it inspiring!?
Actually, I'm just being guided by coincidences, such as getting into the Bugbrand, and stumbling upon offers to buy a few bunches of used bananafrac of other brands. Through this I learned how good the Wiards and the Metalbox modules are - and Blacet. They all complement each other nicely.
But without the bananas - nope
They make everything so much easier and more fun!
/Palle
/Palle
^ congrats palle, I had my eyes on a few of those bits myself, great fun. Still toying with the idea of nanafying the frac stuff at some point, though since Id likely keep the bug and the fracdrum patched seperately Im not entriely sure its worth the effort. Anyway, look forward to hearing it!
Here's my current bug rig:
FxCam_1324577140479.jpg by sonofprent, on Flickr
