[BUILD] stroh fadex plus, frac
synthcube
you will be assimilated
Post by synthcube » Fri Jul 31, 2015 8:33 am
Build thread for the new stroh modular fadex plus for frac-rack
the panel/pcb set is available here:
http://synthcube.com/cart/index.php?rou ... uct_id=692
order your frac cabinets and power supplies from the original blacet research: www.blacet.com
synthcube
this is the placeholder post for the BOM, schematic, build guide and other documentation
frac-fadex-schematic.pdf
(92.12 KiB) Downloaded 42 times
frac-fadex-led-driver-schematic.pdf
(6.64 KiB) Downloaded 18 times
J3RK
Post by J3RK » Fri Jul 31, 2015 10:11 am
Update:
Build docs are now contained in the ZIP file in this thread:
https://www.muffwiggler.com/forum/viewt ... p?t=150552
This is due to Comcast killing off personal web space. I've also given the docs to Synthcube and Thonk just in case. If at some point I get more time on my hands again, I'll set up some hosting, and put these up properly again. I just wanted to make sure they were available again in the meantime.
J3RK
Post by J3RK » Tue Sep 29, 2015 11:09 am
Now that things are moving again, I will get a wiring diagram together for this one first, as it's more complex than the others. I'll start it ASAP.
synthcube
Post by synthcube » Sat Oct 27, 2018 12:45 pm
we've completed the BOM development and kitting for this module. A few beta build kits have been sent out and we are encouraging those beta builders to post their progress, issues, comments here for everyone's benefit...
we're including both 3.5mm and banana jacks in the kits so you have your choice of jack style. We are kitting our black/dark red knobs, but the T18 pots are compatible with b/w Rogan knobs also if you prefer your frac panel monochrome rather than technicolor
https://synthcube.com/cart/stroh-modula ... ption=true
here's the current draft of the wiring:
Rob_C
Re: [BUILD] stroh fadex plus, frac
Post by Rob_C » Sat Oct 27, 2018 9:10 pm
synthcube wrote:Build thread for the new stroh modular fadex plus for frac-rack
Order your frac cabinets and power supplies from the original blacet research: www.blacet.com
Uh, FracRak cabinets and power supplies are also available from the "original" PAIA: www.PAIA.com
Link->PAIA FracRak case
Link->PAIA Regulated power supply
werock
Post by werock » Sun Oct 28, 2018 8:15 am
Is there a functional description of this module anywhere? Obviously it's some kind of VCO, but a description of the 'fade' part would be useful.
J3RK
Post by J3RK » Mon Oct 29, 2018 11:26 am
It's basically two parts.
One part is a VC Crossfader / Panner.
One part is a Triangle Core VCO (with sync, FM, etc.)
So you could do things like automate a crossfade of two signals using the included VCO, or you could use the cross fader to take the triangle and square waves from the VCO, and VC crossfade the shape (similar to a Buchla 258 or the like).
The oscillator has excellent Volt per Octave tracking, linear FM, full reset sync that you can hold indefinitely.
The AC/DC switch is for the coupling on the fader inputs. You could make some fairly complex modulations in LFO mode for example using DC coupling.
That's more or less the idea.
werock
Post by werock » Tue Oct 30, 2018 5:27 am
Thanks for the explanation.
diophantine
Post by diophantine » Thu Nov 01, 2018 3:43 pm
J3RK wrote:One part is a Triangle Core VCO (with sync, FM, etc.
Aside from the fine-tune pot here, is this VCO the same as your PicoVCO?
J3RK
Post by J3RK » Thu Nov 01, 2018 4:12 pm
The main VCO board is nearly identical. The main difference is the shape of the PCB.
fracmonkey
Ordered a kit...
Post by fracmonkey » Wed Nov 07, 2018 10:53 am
But no documentation. Aside from the connection diagram, there seems to be nothing. Schematic would be helpful.
J3RK
Re: Ordered a kit...
Post by J3RK » Wed Nov 07, 2018 12:19 pm
fracmonkey wrote:But no documentation. Aside from the connection diagram, there seems to be nothing. Schematic would be helpful.
I believe I sent those to SC a while back. I'm happy to post them here as well, though I don't have them in front of me at the moment. (at work)
fracmonkey
Post by fracmonkey » Thu Nov 08, 2018 11:30 am
The synth cube built docs have a link to THIS page!
Whose in charge? Sad.
J3RK
Post by J3RK » Thu Nov 08, 2018 11:44 am
I'll attach them here.
frac-vco-core-bom.txt
(2.72 KiB) Downloaded 13 times
frac-vco-core-pcb.pdf
(110.54 KiB) Downloaded 11 times
frac-vco-core-schematic.pdf
(64.98 KiB) Downloaded 15 times
(92.12 KiB) Downloaded 14 times
frac-fadex-pcb.pdf
(131.48 KiB) Downloaded 12 times
frac-fadex-bom.txt
(1.69 KiB) Downloaded 12 times
(6.64 KiB) Downloaded 14 times
frac-fadex-led-driver-bom.txt
(637 Bytes) Downloaded 11 times
fracmonkey
Not so sad...
Post by fracmonkey » Thu Nov 08, 2018 1:39 pm
On the vco core pcb There is an eight pin smt pattern under q101/q102.
No ref des or any markings. Do we just ignore this?
J3RK
Re: Not so sad...
Post by J3RK » Thu Nov 08, 2018 1:43 pm
fracmonkey wrote:On the vco core pcb There is an eight pin smt pattern under q101/q102.
You can use an SMT matched pair if you like, but you would then leave out the discrete PNPs above it. LS358 or SSM2220 will work there. (I use the LS358. They're excellent, log conformant, and half the price of the ADI parts.)
I apologize, I had an annotated version of the BOM. I will see if I can find that, or I will update the current one. There are no changes necessary, just additional notes about things like this.
One more note as this may come up. The caps labeled BP are just 100nF bypass and bulk caps.
syncretism
Re:
Post by syncretism » Tue Jan 14, 2020 10:46 am
Interesting - how does this work? Like, if I latched a voltage to its sync input, would it "stall" the oscillator? If so, that presents some interesting possibilities.
soup
Re: Re:
Post by soup » Thu Jan 16, 2020 12:35 am
yes
syncretism
Re: Re:
Post by syncretism » Thu Jan 16, 2020 12:36 am
yes
Nice.
