Korg Monotribe modifications thread
MUFF WIGGLER Forum Index -> General Gear Goto page Previous  1, 2, 3 ... 37, 38, 39 [all]
Author Korg Monotribe modifications thread
sixart
Hello all! About to embark on my first modding journey thanks to your shared wisdom here. I wanted to add that I used a CTIA<->OMTP adapter to connect a TRRS headset splitter into the Monotribe for MIDI control. It was what I needed to connect with CV on the second ring of the TRRS.
zaphod betamax
Has anyone build a DIY MIDI OUT (only) for their monotribe?
In theory this would act as a CV(Hz/V) S_trig to MIDI adapter when connected to an MS-20???
shurikenyo
How about VCF...can we control the filter cutoff with CV from a eurorack LFO or ENV? Or will the monotribe blow up? internal power rail is 5V right...wonder if it can handle +-12V hmmm.....
zaphod betamax
Does anyone know where to get that little 5 pin? cable that connects
with the serial port on the Monotribe. I want to fab my own MIDI OUT (only)
and want to keep my DIY work as neat as possible.
zaphod betamax
Internal to the VCF is +3.3V, you would have to attenuate whatever signal.
Try tapping a signal into the wiper on the cutoff pot. Can't say how the Monotribe would react. Probably have to crowbar the signal so it does not exceed 3.3V.
CeeJay
Do you mean the 6 pin connector?
You need a JST PHR-6 2mm connector housing like this:
https://www.conrad.de/de/buchsengehaeuse-kabel-phr-jst-phr-6-rastermas s-2-mm-1-st-740728.html
And the matching crimp contacts or ready made crimped cables like this:
https://www.conrad.de/de/litze-gecrimpt-serie-ph-200-mm-808935-jst-748 475.html
Sorry, I have only the links to a german ekectronic shop, since I bought mine there.
For MIDI out you need only 3 cables and it's probably much easier to solder directly to the underside of the 6 pin serial connector.
zaphod betamax
I've also been told a PS2 mouse contains the same connector.
Have not been able to confirm this.
bitflip
This is the one i got - it fits perfect:
https://www.sparkfun.com/products/10361
zaphod betamax
Thanks! I realize now it is a 6 pin JST plug, I have been able ot find it on amazon.ca and mouse.ca.
syntherjack
Hello,
I've read some Wigglers were looking for Korg Monotribe LFO output mod. I made it for my friend and documented here (waveform shots, no cats):
https://syntherjack.net/korg-monotribe-lfo-output/
The most important thing - the schematics. Use it for your own responsibility smile
Hope you find it usefull,
Jack
zaphod betamax
Not sure if this has been added: It is golden!
https://www.youtube.com/watch?v=cDWL5MSgoq0
zaphod betamax
Late to the party, but here is my 4 voice PolyTribe!
https://www.youtube.com/watch?v=3iE38X-LN9I
zaphod betamax
4 Monotribes playing Marriage of Figaro....
bitflip
Literally woodshedding?! hihi
Sounds great, BTW!
Darkside
Mine has been modified by a friend with the simple declicking solution and thus is now almost a new instrument. Before that it was short of impossible to record with it, but now it's a completely different story especially when controlling the Monotribe externally. Yes, at lower cutoff there are some thumps, but it's not that bad overall.
thetaflux
care to share how you de-clicked your MT?
Darkside
Well, all the information about that mod comes from this very thread, so you just need to dig the depth of it. As I'm not all that knowledged in electronics myself and obviously don't want to give out any wrong data, I can say only, that the mod consists of only one cap and that's about it, not sure about the size though.
vanianbulman
Vcs3 wrote:
Vcs3 wrote:
For personal use only, Monotribe MS20 style overlay in Illustrator format: https://www.dropbox.com/s/1v1hq7xub3zy06e/Monotribe_MS20_Final.ai
Enjoy!
Anyone have this file kicking around that wouldn't mind PMing me? I sent Vcs3 a message, but I'm not holding my breath that they'll be online any time soon.
zaphod betamax
Bump from the future.
The Black Wire is the Saw Waveform Out
The Red Wire is the Triangle Out
The Blue Wire is the Main Switch out to VCF
and not shown but the highest position of the switch
is the square wave out. This is the one I mute, as it is
easier to solder.
Infrablue wrote:
bmot wrote:
Infrablue wrote:
Tonight I finished and tested a mute mod for the VCO on the Monotribe..... [SNIP]....Just simply run a wire from any of the VCO wave selector points and run it to ground. I put on a switch so I can turn it off and on.
hey, well done Infrablue, that is a useful mod. loads of people have asked about doing this. Can you confirm where the VCO Wave Selector points are? I borrowed a picture from an earlier post, uploaded by Low_Gain, which should help. I hope he doesn't mind
That's the perfect image to use... it already marks where to do the mod. This image shows where the WAVE outs are... I actually ran a wire from the one marked here in red, but you could do the blue and black one instead. Red is the sine(ish) wave. Then run to ground (with an added switch on the way if wanted).
Was playing around more with it, and I love that I can do just noise sounds and even noise sequences now. The filter seems to have a built in key follower to it so the steps do alter it.
zaphod betamax
Results on Experiment #23B: External ADSR control of Monotribe.
Feed CV from external Envelope via 10k resistor to wiper on Vcf cutoff.
Envelope=MS-20kit
Scene #1 EG1 with Attack/Release and positive going CV. Works great
Scene #2 EG2 Inverted with negative going CV. Works great.
zaphod betamax
Any luck? I own 5, soon to be 6 Monotribes and I would like this overlay.
vanianbulman wrote:
Vcs3 wrote:
Enjoy!
zaphod betamax
an experiment.
zaphod betamax
https://www.youtube.com/watch?v=DfPL8s3jPMI
nicolas3141
This is an epic thread : )
I am quite keen to look at a more sophisticated declick option which leaves attack with a bit of a click, but completely declicks and dethumps the release. Has anyone done that? Should be possible with a couple of opamps forming an asymmetrical slew limiter between the envelope out and the vca in. Just wondering if anyone has tried anything similar before I start hacking my way in there.
Page 39 of 39
