| View previous topic :: View next topic |
| Author |
Evolver sounds |
consumed International Filter Conspiracy
   Posts: 2451 Location: norcal
Posted: Tue May 06, 2008 9:36 am Post subject: |
sick demos zero!
there's plenty of weak analogs even today. but the evolver is not one of those. for a stupidly tiny little box, it screams analog beefiness.
one thing that zero didnt mention is that you can step through the digital waveforms just like a miniwave. i also love the feedback and delay on mine. the desktop is my ultimate portable synth. its outputs are hot enough to drive headphones too.
i dont know if i would have had the patience to program the evolver, until i got into modular and relearned synthesis again. now i can really appreciate all the features in the evolver, and the tonal quality.
i think the evolver would be my analog desert island synth. if i had to run out of my burning house with only a backpack, id take the evolver and some headphones. and some fresh underwear and a toothbrush. a pillow would be good too. _________________ bandcamp
blog |
| Back to top |
zerosum Modulation Maniac
   Posts: 1946 Location: Kalifornyuh
Posted: Tue May 06, 2008 11:53 am Post subject: |
| Quote: |
Are you using the editor software or just programming straight from the hardware? |
I haven't picked up the editor, although I planned to years ago
Just accessing everything straight from the interface which does take some getting used to(I'm still not totally used to it).
The Vyzor editor looks really nice,
but I get this feeling support for it is weak.
I should pick up the soundtower editor soon, like real soon.
Thank you! 8)
I have always enjoyed your demos as well!(i still have quite a few to catch up on....)
| Quote: | | i dont know if i would have had the patience to program the evolver, until i got into modular and relearned synthesis again. now i can really appreciate all the features in the evolver, and the tonal quality. |
I agree. _________________ |zerosuminertia.com| |
| Back to top |
plord Wacky for Wiard Wiggler
  Posts: 998 Location: Charlotte, VT
Posted: Thu May 08, 2008 12:58 pm Post subject: |
I've owned the desktop and mono keyboard versions of the Evolver. I think if you could have ONLY ONE monosynth, you'd be hard pressed to find a better all -around, does everything and then some, supreme value for your dollar synth than the MEK. It can do everything, it can cut like a knife through the densest mix, and with very little effort it will drag you off into usable, musical, freaky noise nirvana. Plus it's tiny and lightweight. I had issues with the desktop programming matrix (sold my Pulse for the same reason), but the MEK's knobtastic interface solved that one; there's very little not to like.
However, over here in reality, I'm a gear whore with multiple monosynths So I swapped both mono Evolvers and some cash (hmmm, probably from selling my redundant Qrack IIRC) for a Voyager. Someday I'll have enough space, power, mixer inputs, and cash in hand to get another MEK. |
| Back to top |
felix Loves the manuals!
   Posts: 3566 Location: Campbell, CA
Posted: Thu May 08, 2008 1:33 pm Post subject: |
The one thing that put me off the Evolver was that the analog oscillators were hardwired to the left and right outputs, so you could pan them internally and have a mono output 2 analog OSC patch (or even a 4 OSC mono output patch, as the digital OSCs ad the same limitation).
Did this ever get changed? A firmware update or anything? _________________ i am escigler
http://felixinferious.blogspot.com
http://felixinferious.bandcamp.com |
| Back to top |
flts Veteran Wiggler
  Posts: 532 Location: Finland
Posted: Thu May 08, 2008 1:36 pm Post subject: |
| felix wrote: | The one thing that put me off the Evolver was that the analog oscillators were hardwired to the left and right outputs, so you could pan them internally and have a mono output 2 analog OSC patch (or even a 4 OSC mono output patch, as the digital OSCs ad the same limitation).
Did this ever get changed? A firmware update or anything? |
do you mean "you couldn't"?
because you sure can now, i you can pan the whole patch either wide stereo, narrow stereo or mono. i think this has been a feature from the start since there's a label for the feature in the programming matrix and i think it's explained even in the old manual.
the bad thing is that i THINK it affects the whole patch, so it's either all stereo patch with oscillators panned L-R or all-mono patch with everything in both channels. |
| Back to top |
| Back to top |
| Back to top |
| Back to top |
Cybananna Funniest Guy
  Posts: 1394 Location: Ohio, USA
Posted: Wed May 14, 2008 11:02 pm Post subject: |
I love my Evolvers. I have the Desktop and the PEK. It's a bit odd though. I use each of them completely different. I never sequence with the PEK and never use a keyboard with the desktop. That seems terribly obvious at first, but I also make totally different sounds, again, related to how I use them. The funny thing is that I prefer the desktop to the PEK. I don't mind the interface at all. That matrix is very friendly. I can make such strange sounds with it. I don't have any Evolver solo stuff handy though. The only trouble I have with them both, but more with the PEK is that they are hard to fit in a mix. The desktop is the mix, it can completely take over, and the sounds from the PEK are too cutting or overbearing or something. It probably boils down to lack of skill somewhere, but I don't have that problem with anything else. I could never get rid of either though.
The perfect one for me would be a polyevolver with a MEK sized keyboard. I'm not a fan of big keyboards usually. |
| Back to top |
Kwote Voltage Controlled Crackpot
  Posts: 3328 Location: SF Bay Area
Posted: Thu May 15, 2008 1:41 am Post subject: |
| Cybananna wrote: | | I'm not a fan of big keyboards usually. |
i'm starting to come around to that same conclusion too. i've got a 61 midi control but i'd love to slim down to 49. _________________ Self expression is as essential as breathing
kwotemusic.com
my other sites |
| Back to top |
synthetic TASCAM Hero!
Posted: Thu May 15, 2008 12:32 pm Post subject: |
These demos sound much nicer than the presets I've heard. I've wanted to like this synth since the beginning but every time I played with it, it did nothing for me. I know a guy who has bought it and sold it twice. I think I'll save my money for the MOTM digital stuff coming later this year. _________________ http://www.jefflaity.com/studio |
| Back to top |
Posted: Thu May 15, 2008 7:22 pm Post subject: |
| Quote: | | I've wanted to like this synth since the beginning but every time I played with it, it did nothing for me. |
I have wanted to master this since the beginning, but so far I'm still stuck in experiment mode.
I know it can do everything I want it to do(Everything is such a big word, I know it can do most of what I want) I just need to get to it.
Its easy to get distracted with it, which is where all the crazy sound demos come from.
This is a very unique synth in so many ways, I should have picked one up way way way sooner.
If I get a software editor or a MEK with a knob for everything and display that eliminates memorizing the 3 digit display readout I think I could really expand.
Sigh.....Imagine the PEK/PER that has 2 outs for each voice!
Thanks everyone for watering this thread!
I'm sure it really gives a lot of people out there some good info on what the evolvers are capable of and why they are so unique! _________________ |zerosuminertia.com| |
| Back to top |
tragedybysyntax *lolweegi*
Posted: Sat May 24, 2008 7:53 pm Post subject: |
Wow..... I finally got around to sitting down and listening to all of these demo's.... I have to get me one of these damn things! lol. I think this baby..... ran midi out into my doepfer midi/cv box... clock gate to my sequential switch.... will be INSANE!!!! Run each channel out thru the modulars filters and waveshapers....MMMMM......... lol.
I'll letya guys know when I finally get one... prolly within the next month or so. Peace! and thanks for all the badass demos!!! |
| Back to top |
| Back to top |
| Back to top |
Kent Large Member
  Posts: 4418 Location: Paris, France
Posted: Tue Mar 09, 2010 9:19 am Post subject: A full album done on a DSI Evolver |
I stumbled across this and knew that I had to post it somewhere on this forum. This thread, although old, seemed appropriate. In order to continue the theme, click upon the mix-tape below. It can be downloaded or streamed.
Scroll down the window on the left for some informational links.
 _________________ Kent™. Putting the 'ass' in "World Class" |
| Back to top |
peh Common Wiggler
 Posts: 117 Location: uk
Posted: Wed Mar 10, 2010 7:56 am Post subject: |
yeah, love my evolver desktop. had it for a few years now but am only just starting to think of getting the sound tower editor for it.
Does anyone here use it? The main thing I would like to know is whether or not it has an apreggiator function as this isn't included with the synth itself.
paul |
| Back to top |
SepticUnderground Zombi Wiggler
 Posts: 500 Location: Netherlands
| Back to top |
peh Common Wiggler
Posted: Wed Mar 10, 2010 10:12 am Post subject: |
Thanks! I'll give it a try |
| Back to top |
de_raaf Wiggling with Experience
Joined: 16 Dec 2009 Last Visit: 08 Sep 2010 Posts: 294 Location: antwerp , Belgium
Posted: Thu Mar 11, 2010 9:59 am Post subject: |
just listening to the sounds here,
need to get more busy again with my mek |
| Back to top |
