iOS ports of Mutable Instruments modules
Author iOS ports of Mutable Instruments modules
th0mas
I've got Plaits running as an audio unit. Not releasing until it's ready, I want to add an LFO, ADSR, and modulation routing first. Then will look at other Mutable classics. Will be a free download.
https://www.instagram.com/p/Bxs9OishfWo/?igshid=lda24i5theex
https://www.instagram.com/p/Bxs4vVnhIWj/?igshid=c2yieo9sdqu8
ngarjuna
Very cool, this will be fun to play with!
phats
Super cool! hmu if you want any beta testing
Phil999
great news
Cool! I guess adding polyphony would be a trivial effort?
th0mas
https://www.instagram.com/p/Bx0evj0AxOk/?igshid=1n3954orm2b
Yep polyphony! Implemented pan spread, oscillator "slop" and unison today. Hoping to get an LFO working tomorrow. Planning on having some basic hardcoded modulation paths (LFO/ADSR to parameters) and eventually a mod matrix that goes deeper.
And a real UI smile
jimfowler
somebody loan me some money to buy an iPad.
th0mas
Added LFO code from Peaks last night.
https://www.instagram.com/p/Bx4ve0KgIHK/
Gotta tweak the range so it can do 30s+ cycles
adam
i thought tides would be nice with this smile
jimfowler
dude, if you can make rings and have it sound right i'm all over it.
th0mas
https://www.instagram.com/p/ByDEnhFg0ha/?igshid=17quv6zsvnevd
Added most of the modulation section. May do a full mod matrix later but not at launch.
Edit: https://www.instagram.com/p/ByFmFc4gS9i/?igshid=19o6hi1wan427
Got elements working last night
CosmicFlight
Wow loving this idea too hyper
Phil999
looking forward for this.
As some may not know, you can attach an iPad to a computer and run the Pad like a plugin (while the processing is done on the iPad). A great feature that was introduced not so long ago.
th0mas
Setting out to do these ports, I really wanted to capture the potential that these modules carry in a modular setup.
Last night I added a mod matrix loosely based on the novation circuit. Each slot multiplies two inputs times a depth parameter and assigns it to an output. The UI only allows for three rules right now but it really opens up the potential of the synth.
Now I can build the modulation section of the elements synth and then start on Clouds.
https://www.instagram.com/p/ByNOaJog2Ns/
jimfowler
sounding awesome!
jbuonacc
is this feature only available on a Mac computer?
bengarland
Can you post a link that explains this? First I've heard of it, and I have no idea what to google to get more info... it's not clear if this is something built into iOS, or some other software... ?
Phil999
on Mac it is called IDAM or something like that. I have no experience with this, I never had a Mac.
I created a new discussion about it so we can concentrate on each topic separately:
https://www.muffwiggler.com/forum/viewtopic.php?p=3072372#3072372
th0mas
https://www.instagram.com/p/ByqDFQAAuaD/?igshid=jg8hc1kco68n
Still a ton to do!
