BENJOLIN 4U
MUFF WIGGLER Forum Index -> Buchla, EMS & Serge Goto page 1, 2  Next [all]
Author BENJOLIN 4U
anto32
Hi,
Now the module works as it should.
Big thanks to Rob Hordijk, the help of the brilliant Mr Dave Brown and the perfect panel work of Julian (Thebeast)
Description :
Audio outputs normaled :
- Square 5 pk-pk
- Triangle 4 pk-pk
- XOR 5 pk-pk
- PWM 5 pk-pk
- VCF Out is approx. line level
I've added a jumper to disconnect the PWM that is internally wired to the filter.
- 1.2V Inputs _ these vcos are not super stable but 3 octaves tuned decently_ there's trimmers on the back to adjust each vcos
- CV Attenuverters
- Clock In & Serial In : Feed with external signal (at least 2V) Trig, gate, or CV. External is activated when switch is down.
Pulser from 208 is a bit to short to fire it. Works with 281, 245, TSNM, 259 square and saw waves, uStep, Klee sequencer, LFO, 266 outputs, 208 envelope...
- Bit 1/2/3 : Gate Out 15v - when led light on : Gate=0
- Stepped : It's the Rungler CV output, 8 stepped voltage (S&H sort of). Maximum range from 0.5 to 12v. It can be trimmed.
One "scale" I find useful to shift the stages of the 245. 1,2v/2.6v/4v/5,4v/6,8v/8v/9.5v/10.8v
- Switch mode : 8 steps / Random / 16 steps
- PushButton : Manual Trigger Serial In = change the pattern of the Rungler when pressed.
- 2-pole VCF with Rungler CV control and attenuverter.
Early proto
island
Wow thumbs up looks great.
MATSmile
What a beaut nanners
tIB
Nice! If I remember right the Metatron generator by vedic scapes covered similar ground...
snufkin
wasn't it basically an unlicensed copy hmmm.....
vgermuse
Woah!
DomMorley
3 octaves tuned? Well this is interesting.
sparks
pbear :(
Prunesquallor
I'd be interested in a LW Serge version of this.
hox3d
I actually worked on a layout, but I got no time to do it.
It might need some more labeling, but the main idea is here.
Prunesquallor
Nice!
cygmu
Is this one licensed somehow then?
tIB
No idea, just remember it was a thing.
ynth
This looks incredible. The Chewbacca Defense
Reality Checkpoint
+1
CLee
+1
My 4U Benjolin. IIRC it was a FPE panel with Lazertran art. I'd be happy to share the layout and art if anyone wants it
fluxmonkey
nice pairing!
knittingram
SlayerBadger! SlayerBadger! SlayerBadger!
Keeping an eye on this!
anto32
Yes, I got a lcence agreement to make it. Sorry if it was not clear.
Many thanks for your feedback and interest!
I keep you in touch.
cygmu
anto32 wrote:
Yes, I got a lcence agreement to make it. Sorry if it was not clear. .
Yay! That is great news! It's peanut butter jelly time! nanners
snufkin
It was clear to me that you did sorry to derail the thread smile
great work.
bsilverberg
Looks great! Will the panel be available for sale or will the final fpd be made available? Thanks!
julian
It is Anthony's design, but, from conversation, i think that his plan is to do an initial run, and then, at some point, release the fpd.
The panel photo in the first post was engraved. When its finalised, it will be silk screen printed.
I will certainly be printing the primary run in the usual materials / inks but its very much Anthony's project, so his call on how the parts are released.
(i just chop metal!)
jo__dem
sign me up for one
myecholalia
Following this with interest.
Do you have a rough timeline in mind for a first run?
