Every 208/easel needs a new card 12 diy pcb or built card ;)
MUFF WIGGLER Forum Index -> Buchla, EMS & Serge Goto page 1, 2  Next [all]
Author Every 208/easel needs a new card 12 diy pcb or built card ;)
boops
Every 208/easel needs a new card 12 available now
29 09 2019
Pcb in stock
New 208 card 12 available
Dave Brown built
papz
Is there a reverb mix CV input ?
lumin
Does this also work with BEMI/BUSA easels?
Fuzz
What does this do?
muncky
Check the link at the top - takes you to the thread with the background and sound files too
Looks interesting, Boops!
boops
good idea ,but which hardware (reverb level banana cv in)?
boops
i dont know for the moment .
boops
papz
Any banana socket can be rewired and used as a reverb mix CV in, for example a "pressure" one, who needs 4 of these ?
davebr
I bought one of these and upgraded my 208. It is definitely an improvement. I added a Boops Card 12 Replacement page to my website with photos.
I felt a little like the cobbler's children so I took the opportunity to add a number of mods to my 208 while I had it on the bench. I kept finding and modifying other's 208s but never went back and added them to mine. Now it performs much better.
Dave
edwinm
Which mods did you do Dave?
davebr
They are all listed on my page. From memory:
Adjusted the AM level so it is the same as FM and BM (resistor tweak)
Adjusted the CO HF trim (resistor tweak)
Adjusted the MO offset (resistor tweak)
Adjusted the CO offset (added a resistor)
Adjusted the timbre so it is always stable (resistor tweak)
Modified the AM so the control goes 0 to 100% and doesn't over-modulate
Adjusted the CO coarse slider so it doesn't flatten at the top (added a resistor)
Changed the contour of the reverb mix control (added a resistor)
and then I rescaled for 1V/Oct so it would play nicely with my 258s and my 5U system.
Previously I had tweaked the sine with resistor changes for a good shape. Mostly the mods are simply improving performance by fine tuning things.
The AM does over-modulate which in itself could be a feature, but it seems rather odd to me and really makes the output quite hot.
Dave
Siri
Thanks Boops and thanks Dave! w00t This is fun!
boops
A reverb mix level CV circuit (vactrol based) is ready to test,more in a few days
boops
It works,i have just to adjust some parts wink
Minimoog56
You selling these prebuilt Boops?
boops
Yes ,pm me please
boops
Finished
demo here
https://www.muffwiggler.com/forum/viewtopic.php?p=3064533#3064533
boops
Pcbs available
b4
Any news if your card 12 works in a BEMI Easel?
boops
Unfortunaly,no bemi easel around me ,thanks for your interest.
Fuzz
Want to send me one and I'll let you know if it works? cool
boops
Not sure it is a good idea ,a bad voltage connection will burn some parts ,sure.
boops
pcb in stock
Rockin' Banana!
ArguZ
Hi guys, i have a question regarding a component
C5 1 75-MKT1813368014 Film 6.8nF 100V 5% axial
The part resolves a 68nF cap, not a 6,8nF cap
What is correct ? The part number of the value ?
