Buchla USA announces Red Panel
mgscheue
Post by mgscheue » Fri Oct 18, 2019 4:55 pm
My 158.
beyourdog
Post by beyourdog » Thu Oct 31, 2019 8:48 pm
I was wondering on the back of the catalyst audio or any other red panel modules what the purpose of the jumpers was exactly...
mgscheue
Post by mgscheue » Fri Nov 01, 2019 5:58 am
I think they set the audio and CV levels to Euro or original Buchla levels.
J3RK
Post by J3RK » Fri Nov 01, 2019 10:43 am
Interesting!
Those boards are nicely laid out. I also notice they're using the J201 for sine shaping. Something that started I believe during some of the first 258 cloning work at Electro-Music way back when.
:party:
beyourdog
Post by beyourdog » Fri Nov 01, 2019 11:40 am
mgscheue wrote:I think they set the audio and CV levels to Euro or original Buchla levels.
thanks for that
Peake
Post by Peake » Fri Nov 01, 2019 1:11 pm
J3RK wrote:Interesting!
:party:
The J201's low Idss range (usually 0.2 -0.8) makes it perfect for the 158's triangle shaper which according to the schematic requires a selected 0.5 Idss E101, which are no longer available. The remaining J201 at smallbear are in this range and are fine. For a while they had higher-measuring 201s but they're now gone.
The 201s are acceptable for the 258 clones (sine shaper section) requiring a higher Idss, when they measure 0.8 or above.
Warning to people buying 2N4339 from ebay for Buchla builds...some less-expensive devices can be sub-standard and behave out-of-range.
I just can't help imagining that this would be better with vactrols
pre55ure
Post by pre55ure » Sat Nov 02, 2019 12:37 pm
:party:
Thank you Dustin! I've built a lot of your boards over the years so thats nice to hear.
The J201's are the best thing available for the tri -> sin conversion at the moment. Unfortunately (in my experience) there is a LOT of variation in how well they work. I have just taken to purchasing a large amount of j201's off of various ebay sellers and then actually testing them individually in circuit to determine if they look/sound ok. I'd say on average only about 50% make the cut. Sometimes an entire bag is no good, sometimes 80% are good.
Also - just to confirm, yes the jumpers are to set the audio output level. Euro is in the 8v to 10v PP level, and Buchla is around the 1.5 to 2v PP level
beyourdog
Post by beyourdog » Mon Nov 04, 2019 5:11 pm
:party:
Thanks a lot for this. Really enjoying the Catalyst and Red panel modules and having to think everything in a dual / stereo way.
Is there any plan to make the Red Panel Low/High Pass / Band Pass filter model 191 available anytime soon?
thanks :party:
beyourdog
Re: Buchla USA announces Red Panel
Post by beyourdog » Thu Jan 09, 2020 8:07 am
Any new Red Panel modules scheduled for 2020?
mgscheue
Post by mgscheue » Sat Jan 18, 2020 3:25 pm
This is a bit curious: Buchla rather than Red Panel branding, though David refers to them as Red Panel in this post.
Charlie Labs
Post by Charlie Labs » Sat Jan 18, 2020 6:47 pm
I wonder if they're just prototypes. I don't mind either look/name, but when I start picking them up I'd like them all to match. OCD intensifies =P
moremagic
Post by moremagic » Sat Jan 18, 2020 10:25 pm
look closer, theyre labeled with RP1xx model numbers :miley:
pprobably figured they could profit more by losing the red ink and adding dons name
Post by 01235813 » Sun Jan 19, 2020 12:02 am
Much prefer this to the "Red Panel" that I had seen in other demos. This may just enable my dive into euro..
Buchla seems to be "on fire" at the moment. I'm so happy that Mr. Fox took the dive!
Ossicle
Post by Ossicle » Sun Jan 19, 2020 6:28 am
Could it be that they are finally realizing that hardly anyone liked that silly red panel logo. :roll: But I'm hoping they make the 4U versions properly and release them soon.
Post by 01235813 » Sun Jan 19, 2020 3:50 pm
Peake wrote:
Sun Jan 19, 2020 1:54 pm
If Buchla make 4U proper 100 Series modules I sure hope they'll involve me at some level.
First off let me take the moment to say that I really respect your blog and the work that you have put into the 100. :hail:
You put this out there so I hope you don't mind the question: in what way would you like to see Buchla involve you in their endeavour?
Really out of curiosity and unknowingness, would they be using information that you made available on your blog?
Peake
Post by Peake » Tue Jan 21, 2020 1:33 pm
Thanks to the mods for removing my self-pitying rant. This is Catalysts's thread, not mine.
