CV controlled switch modules you love
Author CV controlled switch modules you love
ScientificDreamz
While building my system I've stayed away from sequential switches and other routing modules as they seem 'boring' compared to uber-cool oscillators/FX/filters, but now realising the benefits more.
I was looking at a simple Doepfer switched multiple, but then thought I'll probably appreciate being able to switch between two sequences with a trigger pulse. There's loads of capable modules on the market and tricky to know which are best without demo-ing, do people have specific modules they love for this job? Cheers! smile
I love the Klavis Mixwitch. It does swtiching and a lot more (check the manual), feels well made and is priced very kindly. My best value buy yet, I think.
https://www.modulargrid.net/e/klavis-mixwitch
For a basic but versatile 1 I/O to 4 O/I sequential switch the Doepfer is hard to beat:
https://www.modulargrid.net/e/doepfer-a-151
The ADDAC214 is a 4 I to 4 O sequential switch so even more powerful for scrambling things up and also adds CV control over position:
https://www.modulargrid.net/e/addac-system-addac214-black
The STG Switch is a 4 I to 4 O switch that has some great features too. I just took delivery of the 5U version but I haven't tried it yet. It looks like the eurorack version has the same feature set.
https://www.modulargrid.net/e/stg-soundlabs-switch-
And if you have the room don't write off the Doepfer A-182-1 you were considering and get both. cool Some times a manual switch is all you need. (I modified mine )
https://www.modulargrid.net/e/doepfer-a-182-1
Naenyn
I was planning on picking up an Erica Sequential Switch V2. I've quite liked Erica's stuff so far and that module seemed like a good value for the money and size.
That Mixwitch looks interesting! Not what I had in mind for a switch, but I can see the usefulness. Nice design, too. Sharp.
huffnPuff
I love digitally addressed things.
Take a look at the NLC Statues for example: it’s a 3 bit addressed switch/ T&H. It has 3 digital inputs that map to a 1-8 address space, selecting one active channel out of 8.
Another good one from NLC is the Numberwang. This one has four binary inputs that map to a 1-16 address space. Combine this with a VCAM and you have a powerful 4x4 multiplexer.
If you are already running trigger sequencers to drive your rhythms, they can also be used to route modulation and audio around. All you need is a stack of VCAs and trigger sources. The VCAs will pass through signals when a gate is high and mute them otherwise.
What the modules I mentioned do is open a single route and close all the others but nothing is preventing you from routing one source to multiple outputs simultaneously, or multiple sources to a single output, or multiple sources to multiple outputs all at once.
To bridge the gap between analog an digital I use a Drezno, so I can use an LFO or a S&H or any analog modulation source.
Foghorn
I have an Erica Pico SEQS.
CV controlled Sequential Switch.
It sits right next to my Pressure points.
It even color matches them.
Works a treat.
And no, I didn't mistakenly buy it thinking it was the Pico sequencer. d'oh!
Pico SEQS on Modgrid
Foghorn
jwm
+1 on the erica v2, it is an amazing switch. crazy versatile for the space and $$. switching cv is great, but i use it almost exclusively for switched audio ie switching through verbos HO sines, or individual qu-bit chord outputs for harmonically related crazy blippy madness.
(btw, full disclosure, i am selling mine if anyone is interested, only because i am transitioning to an all doepfer system, other wise i'd have two hihi )
mdoudoroff
If you’re doing a medium-sized or larger system, I think the WMD Sequential Switch Matrix is one of those must-haves.
The Mixswitch—mentioned above—is pretty neat, too. Great value in a multi-function device.
Speaking of multi-function devices, don’t overlook the new Befaco Muxslicer, which DivKid just did a video on. Clever and cheap.
pugix
Softwire Synthesis - Octal Voltage Controlled Switch has both manual and gate controlled switches.
https://www.modulargrid.net/e/other-unknown-softwire-synthesis-octal-v oltage-controlled-switch-ovcs
Stages also makes a great sequential switch.
https://www.modulargrid.net/e/mutable-instruments-stages
maaaks
ALMs Boss Bow Tie is worth considering too:
https://www.modulargrid.net/e/alm-busy-circuits-alm007-boss-bow-tie
It's CV addressed rather than sequential which may or may not be what you're after.
dooj88
can anyone attest to the quality of their switch of choice with audio routing? my a151 isn't the smoothest and i often hear pops and clicks. would love to find another that can handle audio more gracefully.
CaneMan
woah
I just got a Joranalogue Select 2. It's 2 cv processors, each of which can do track-and-hold, 2 input -> 1 output CV switching, etc. Haven't even taken it out of the box yet, but I think I'm going to love it.
huffnPuff
Try placing a buffer immediately after the switch, it helps with the A-152.
mdoudoroff
Any switch could produce clicks and pops with audio unless there’s fancy (expensive) zero-crossing circuitry or some fancy (expensive) per-channel VCA action going on. I don’t know whether any such fancy (expensive) switches actually exist in the market. Mainly a problem with low frequency and sines, less a problem with stuff with harmonic content.
Dcramer
A-152, both CV and trigger controlled, 8 channels :
Frames, 4 channels of bidirectional switching, morphing, mixing/splitting thumbs up
hermbot
I love my RxMx for this. It can be a voltage controlled switch and/or crossfader. Or a mixer, or a low pass gate. And it has great synergy with both my DPO and FXDF.
RxMx is really expensive for someone looking for simple switch, though.
titanium
WMD SMM
https://www.wmdevices.com/products/sequential-switch-matrix
4 in 4 out switch matrix, with 16 matrix steps that can be sequenced.
bit heavy on the HP, but def an amazing tool for routing CV or Audio.
Buttons ARE toys
I've been getting a lot of mileage out of Macro Machines' Dynamic Destiny. It's dual channel, each switch can be 1 in 4 out or 4 in 1 out. What makes it great though are all the different modes it can run in--built in clock division, disabling of unneeded i/o, control over which direction the switch progresses including random and pendulum. It's discontinued but they pop up used pretty often.
MvK
I had some fun with the Ryo Paths. Its cheap for what it does.
pugix
Maybe not in Eurorack. But MOTM-700
http://synthtech.com/motm/700/
pugix
Didn't see Maze mentioned.
https://www.livestockelectronics.com/maze
ScientificDreamz
Loads of cool options here, thanks.
I think my ideal module is very simple, 2 channels of switching, each one with two switchable inputs linked to a single output, toggled between via a trigger pulse. Basically a Doepfer A-150 but with the switching controlled by trigger pulses, rather than sustained voltage
https://m.thomann.de/gb/doepfer_a_150.htm
Any ideas? Ryo paths seems closest maybe
Possibly two Ladik S-220 switches? hmmm.....
http://ladik.ladik.eu/?page_id=2319
hinterlands303
Doepfer a-151 (v2) will do this. It can be anywhere between 2 and 4 channels of switching (bi-directional). You can control the number of active channels by a toggle switch. Also you can do this with an Erica Pico Seqs but you use a voltage rather than a switch to control the active channels (which is a little more work but leads to some other cool possibilities). I have both of these switches and they are both great for different things. Sounds like for you the Doepfer a-151 might be the best fit though.
Page 1 of 3
