Best EQ for feedback noise with distortion
MUFF WIGGLER Forum Index -> Synth Noise
Author Best EQ for feedback noise with distortion
jbaptiste64
What is the best equalizer for feedback noise?
EQ 3 bands (HI ; MID; LOW)
OR
EQ 3 (HI, HI MID, LOW MID, LOW)
I hesitate between these two mixing tables.
https://www.thomann.de/fr/behringer_xenyx_x1204_usb.htm?ref=search_rsl t_BEHRINGER+XENYX_243148_23
https://www.thomann.de/fr/behringer_xenyx_x1622_usb.htm?ref=search_rsl t_BEHRINGER+XENYX_243140_22
Noisefan
Are you trying to subdue noise or enhance it?
Anyway, more control is probably better but something with sweepstake parametric eq is far more 'playable' than basic low/mid/high.
sutekina bipu-on
I think your priority should be finding something parametric and with overlapping bands so you can cut and boost the same frequency.
TTTTT
you can also try a simple matrix mixer 4x4, very easy to build and lot of feedback exploration..
sexcomputer
also, don't underestimate inserting a graphic eq into your signal chain, there are cheapo pedals and expensive rack mount units and all points in between. oh if i had the time and ability to build all the module ideas i have...
Mantaray
I second the graphic EQ suggestion, especially with noise since you dont have to tune to precise frequencies (graphic eq's are fixed). Try comb filtering one or more channels, if more than one then do an opposite bands with the second one. Try feeding back into the EQ, and also feed forward (dry signal parallel with the EQ'ed). Try delaying the dry signal. All sorts of phasing and flanging effects possible just with a graphic EQ and maybe a delay. Very versatile tool to have.
PapaLazarou
MXR 10 band
Best to have one with kill switches or add them.
PapaLazarou wrote:
MXR 10 band
I like the Boss GE-7 myself. Excetpionall clean for an EQ pedal. Nice range, great quality. I want to get the bass version GEB-7.
