Erogenous Tones cv8
Author Erogenous Tones cv8
nimmen
http://erogenous-tones.com/modules/vc8/
VC8 is a high density VCA module designed to give you a large number of VCAs with CV level and OFFSET control, along with optional VCA controlled dual sub-mix capability.
This looks very interesting, maybe someone could point me out to similar modules in terms of functionality?
mharpum
I was going to get the levit8 module but heard the pots are more wobbily than harvestman stuff, personal preference for me but I like my knobs solidly bolted with no wobble!
I got 2 ALM tangle quartets for vca duties, they have individual and mix out, I think they are great!
spudboyblues
mharpum
I had and recently sold off the Levit8 — not because the knobs were wobbly, but because the module itself felt crammed. As far as a utility :: real estate ration is concerned, there's no better combo of Levit8 and this new VCA. But sometimes it might feel a tad too tight!
nimmen
Thanks for the input guys, as my setup is more towards live performances oriented, I'll better get two 3/4 channel ones this time, especially since I need them in a bit different positions on the rack.
Rick Burnett
Pots on the LEVIT8 and VC8 are different, on the VC8 they panel mount.
The size target on LEVIT8 is what lead to the decision to using non-panel mount pots. I know some people aren't fans of this style, but I've never had an issue with the quality of the pots, I went through like 4 or 5 versions before I selected these. The nuts and LED spacing just didn't work.
If you look down the side, you'll see there is no extra room between the pots, the LEDs, the switches, and the jacks. There are a LOT of mixing/utility modules, so the design on this one was for size. I use multiple ones in my setup so I needed them to be smaller.
Basically, high density was the target.
potatobrain
Almost everything is perfect about this module. If only it has an exponential switch.
Daveyp
I agree. An exponential option would be perfect.
js213
Is the VC8 DC coupled? I didn't see anything in the specs saying it could be used to control CV signals.
morphlex
From Rick:
It is in fact DC coupled!!!
js213
morphlex wrote:
From Rick:
Excellent. Thanks for the confirmation.
mdoudoroff
Y’all need better envelope generators. lol
slumberjack
what exactly do you mean by that?
slumberjack
double post
wiperactive
I'm quite surprised this module doesn't get more attention considering it's facilities. One thing that trawling through all the threads hasn't really revealed is the audio quality/characteristic of the VC8 in comparison to other VCAs. Any thoughts or observations from users here?
I've just bought the ET Radar and will probably get the VC8 as it's natural partner, though I've also been tempted by the simpler SSF Muton (love those soft mute buttons) which, I believe, has a reasonably clean sound. Any one using this combination?
batch
I have all of them (RADAR, Muton, VC8) and use them together. To my ears they are super clean and great combinations.
akrenaut
I have both the VC8 and Levit8. They are used in every patch I make. Both great modules. Solid construction and clean signals.
wiperactive
Thanks for those assessments batch and akrenaut. I was hoping for the word "clean" rather than "characterful" or "coloured" (not a bad thing in some instances).
The apparent 'philosophy' of these ET modules would lead one to expect this but you can never be sure until they're sitting in your rack.
